hi my mb 800 wont go into third gear any ideas thanks
MBtrac 800 gearbox problem
Hey Mike,
without further informations nobody will be able to help.
Has you trac the shifting levers in the middle or on the right side of the cab? Do you know the serial number of the gear box? Are there vibration or noises while you try to shift? Does it feel like the lever is blocked? Is the trac running or standing? Which combinations of the shifting levers positions have you tried?
Best reagrds,
Michael
Best reagrds,
Michael
Hello Michael,
The gearhandles are in the middle, it feels like the third gear is blocked. Won,t shift at all into third gear. It,s the same in all the ranges. There is no vibration or grinding. I,ll have the serial number for the gearbox in a few days.
Thanks for your help. Mike
Gearbox type MB Trac 800
hdcdenham
Letzter Beitrag von Hondapete
26.11.2013, 22:49
26.11.2013, 22:49
MBtrac 800 Gearbox issue
Mattias
