Themen: 3
30.01.2012, 23:34
Hello!
I have an Mb trac 800 (1980). My problem is the gear in the rear is out. Which type gear is in this trac UG30 or UG27/2 ?
Sory my english is poor.
thnk you for help
Themen: 3
30.01.2012, 23:43
Hallo!
Ich habe ein MB Trac 800 (1980). In der Entsorgung des Wendegetriebes zu laden. Was ist falsch? Welche Art von Antrieb ist das? UG30 und UG 27 / 2?
Jede Hilfe danke.
Themen: 3
30.01.2012, 23:44
Hallo!
Jede Hilfe danke.
Themen: 31
Hello Yolko,
first of all: Welcome in this forum!
Second: where you're from? Your english is quite understandable. But maybe there is a member in this forum, who speaks your language, and english or german, and he can translate. That's the reason of my question...
Third: please do not try to translate into german with some sort of internet-translator. The sentences this translator produces are completely unreadable....
Sorry, can't help you with the transmission problem.
Themen: 3
HI !
I' m from Hungary. I have a problem with the transmission. The reverse speed is throw out when the load is more. Which type transmission is in this trac? MB trac 800 (1980) UG30 or UG 27 ?
thank you for help
Themen: 7
Hello Yolko.
You have the UG2/27 transmission.
I would guess that the synchro rings is probably worn out..
Greetings from Norway,
Haavard.
Mercedes-Benz, The Star...
Themen: 3
Thanks. I was also thinking this. Someone knows an address where you can get such a thing?
