Trac 800 314 to 352a engine swap - Druckversion
+--- Thema: Trac 800 314 to 352a engine swap (/showthread.php?tid=38140)
Trac 800 314 to 352a engine swap - Aussie MB - 21.07.2021
Hi,
I have a MB Trac 800 with a blown engine, problem in getting a new OM314 is that I am located in Australia, and there isn't a great deal of MB engines available.
I can get an OM352a easy enough, has anyone done the conversion?
Any information would be appreciated,
Thanks.
RE: Trac 800 314 to 352a engine swap - Hartmut - 21.07.2021
https://www.trac-technik.de/piwigo/index.php?/category/19
Gruß Hartmut admin
RE: Trac 800 314 to 352a engine swap - Aussie MB - 21.07.2021
(21.07.2021, 10:14)Hartmut schrieb:  https://www.trac-technik.de/piwigo/index.php?/category/19
Gruß Hartmut admin
Cheers thanks Hartmut.
Big job by the looks of it!
RE: Trac 800 314 to 352a engine swap - LLU TJ - 21.07.2021
Hi Aussie,
welcome to the greatest community of MB trac worldwide. Nice to see somebody from the other side, here. Whenever you should have problems with google translate to understand an article, do not hesitate to contact me.
And our big boss and founder Hartmut appreciates to see the name of the user.
So, enjoy the biggest MB trac cyclopedia.
BR
Tim
RE: Trac 800 314 to 352a engine swap - Franz Josef - 21.07.2021
Hello Evan,
a very warm welcome!
You can see: it is possible to swap the engine from OM314-4 to OM352a-6 cylinders.
We have some discussions and postings here in the community about this.
In Germany this change is normally not conform with our legal requirements. Our TÜV = technical inspection agency is very strict.
Two points of this discussions I remember:
Because the engine is longer you have to enlarge the frame or replace the tank of the hydraulic system.
The higher torque of the OM352a is perhaps critical for the gearbox.
If you want to make the change, please give us many pictures.
In the internal section Das bin Ich ...
https://www.trac-technik.de/Forum/forumdisplay.php?fid=12
you have the posibility to tell us something about you.
It is optional!
Your questions are welcome.
Best regards
Franz-Josef
RE: Trac 800 314 to 352a engine swap - Aussie MB - 22.07.2021
(21.07.2021, 15:18)LLU TJ schrieb:  Hi Aussie,
BR
Tim
Thanks Tim,
Looking forward to contribute as I build the 800.
Regards,
Evan.
(21.07.2021, 22:24)Franz Josef schrieb:  Hello Evan,
It is optional!
Best regards
Franz-Josef
Hi Franz-Josef,
I will put up pictures as I proceed with repairs,
I was in the Army for many years and drove Unimogs regularly,
Hopefully the 6 cylinder and gear box get along in the 800.
I will post pictures as I go and no doubt be asking a lot of questions.
Regards,
Evan.
RE: Trac 800 314 to 352a engine swap - M-Driver - 22.07.2021
G’Day Evan,
Nice to see you found your way to this community.
I lived in AU for 4 years working at the Rio Tinto smelter in Bell Bay, Tassie and saw the occasional MB trac floating around, though most of those were in terrible condition.
I believe you are located in WA? You probably should put a pin on the user map!
And yes, upload pictures. People here will appreciate getting a feel for the area you live in and the things happening at your farm.
Cheers,
Gerd.
