Oil cooler torques om352 - Druckversion
+--- Thema:  Oil cooler torques om352 (
/showthread.php?tid=29161)
Jonasbe -  25.11.2015
Hello, i hope you accept me to write in english!
I have a question about the oil cooler and the tightening torques on that one on a om352. I have changed it because of a crack in it but now i get water in the oil and have to get it off again an check the seals.
Thanks! / Jonas
RE: Oil cooler torques om352 -
Stoll30 -  25.11.2015
Hello Jonas,
no problem to ask in english.
According the repair manual the bolts have to be fixed to a torque of 40Nm. Beginn with the bolts in the center, fix them crosswise and follow to the outer bolts.
Good luck in proceeding your work!
Cheers
Benedikt
Thanks for answear! Will fix It in the weekend!
/ Jonas
